查看: 35426|回复: 1
纯ROS2环境底盘节点报错
发表于 2021-8-18 09:54:36 | 显示全部楼层 |阅读模式
大佬们好
我在Ubuntu 18中安装ROS2 Eloquent,没有安装ROS1环境。安装依赖后能成功编译“wheeltec_ros2”,但是运行底盘节点"turn_on_wheeltec_robot"时有如下报错。网上查找资料仍没有头绪,请问能否帮忙排查一下,告知可能的解决方向?
万分感谢。
Log:
  1. 1629123852.5528913 [INFO] [launch]: All log files can be found below /home/ubuntu/.ros/log/2021-08-16-14-24-12-359217-ubuntu-2150
  2. 1629123852.5536616 [INFO] [launch]: Default logging verbosity is set to INFO
  3. 1629123852.8116174 [ERROR] [launch]: Caught exception in launch (see debug for traceback): "package 'joint_state_publisher' not found, searching: ['/home/ubuntu/wheeltec_ros2/install/wheeltec_slam_toolbox', '/home/ubuntu/wheeltec_ros2/install/wheeltec_robot_urdf', '/home/ubuntu/wheeltec_ros2/install/wheeltec_robot_nav', '/home/ubuntu/wheeltec_ros2/install/simple_follower_ros2', '/home/ubuntu/wheeltec_ros2/install/turn_on_wheeltec_robot', '/home/ubuntu/wheeltec_ros2/install/data_collection', '/home/ubuntu/wheeltec_ros2/install/wheeltec_robot_msg', '/home/ubuntu/wheeltec_ros2/install/wheeltec_robot_keyboard', '/home/ubuntu/wheeltec_ros2/install/wheeltec_cartographer', '/home/ubuntu/wheeltec_ros2/install/usb_cam', '/home/ubuntu/wheeltec_ros2/install/tf2_tools', '/home/ubuntu/wheeltec_ros2/install/slam_gmapping', '/home/ubuntu/wheeltec_ros2/install/serial', '/home/ubuntu/wheeltec_ros2/install/rplidar_ros2', '/home/ubuntu/wheeltec_ros2/install/robot_localization', '/home/ubuntu/wheeltec_ros2/install/openslam_gmapping', '/home/ubuntu/wheeltec_ros2/install/nav2_system_tests', '/home/ubuntu/wheeltec_ros2/install/nav2_bringup', '/home/ubuntu/wheeltec_ros2/install/navigation2', '/home/ubuntu/wheeltec_ros2/install/nav2_dwb_controller', '/home/ubuntu/wheeltec_ros2/install/nav2_controller', '/home/ubuntu/wheeltec_ros2/install/dwb_plugins', '/home/ubuntu/wheeltec_ros2/install/dwb_critics', '/home/ubuntu/wheeltec_ros2/install/dwb_core', '/home/ubuntu/wheeltec_ros2/install/nav_2d_utils', '/home/ubuntu/wheeltec_ros2/install/dwb_msgs', '/home/ubuntu/wheeltec_ros2/install/nav_2d_msgs', '/home/ubuntu/wheeltec_ros2/install/nav2_waypoint_follower', '/home/ubuntu/wheeltec_ros2/install/nav2_recoveries', '/home/ubuntu/wheeltec_ros2/install/nav2_planner', '/home/ubuntu/wheeltec_ros2/install/nav2_navfn_planner', '/home/ubuntu/wheeltec_ros2/install/nav2_core', '/home/ubuntu/wheeltec_ros2/install/costmap_queue', '/home/ubuntu/wheeltec_ros2/install/nav2_costmap_2d', '/home/ubuntu/wheeltec_ros2/install/nav2_voxel_grid', '/home/ubuntu/wheeltec_ros2/install/nav2_rviz_plugins', '/home/ubuntu/wheeltec_ros2/install/nav2_map_server', '/home/ubuntu/wheeltec_ros2/install/nav2_lifecycle_manager', '/home/ubuntu/wheeltec_ros2/install/nav2_bt_navigator', '/home/ubuntu/wheeltec_ros2/install/nav2_behavior_tree', '/home/ubuntu/wheeltec_ros2/install/nav2_amcl', '/home/ubuntu/wheeltec_ros2/install/nav2_util', '/home/ubuntu/wheeltec_ros2/install/nav2_msgs', '/home/ubuntu/wheeltec_ros2/install/nav2_gazebo_spawner', '/home/ubuntu/wheeltec_ros2/install/nav2_common', '/home/ubuntu/wheeltec_ros2/install/behaviortree_cpp_v3', '/home/ubuntu/wheeltec_ros2/install/ackermann_msgs', '/opt/ros/eloquent']"
  4. 1629123853.6802182 [INFO] [wheeltec_robot_node-1]: process started with pid [2161]
  5. 1629123853.6812713 [INFO] [cmd_vel_to_ackermann_drive.py-2]: process started with pid [2162]
  6. 1629123853.6821418 [INFO] [static_transform_publisher-3]: process started with pid [2163]
  7. 1629123853.6830151 [INFO] [static_transform_publisher-4]: process started with pid [2164]
  8. 1629123853.6876943 [INFO] [cmd_vel_to_ackermann_drive.py-2]: sending signal 'SIGINT' to process[cmd_vel_to_ackermann_drive.py-2]
  9. 1629123853.6919022 [INFO] [wheeltec_robot_node-1]: sending signal 'SIGINT' to process[wheeltec_robot_node-1]
  10. 1629123853.7373438 [wheeltec_robot_node-1] terminate called after throwing an instance of 'rclcpp::exceptions::RCLError'
  11. 1629123853.7421701 [wheeltec_robot_node-1]   what():  Failed to create interrupt guard condition in Executor constructor: the given context is not valid, either rcl_init() was not called or rcl_shutdown() was called., at /tmp/binarydeb/ros-eloquent-rcl-0.8.5/src/rcl/guard_condition.c:69
  12. 1629123853.7945805 [ERROR] [cmd_vel_to_ackermann_drive.py-2]: process has died [pid 2162, exit code 1, cmd '/home/ubuntu/wheeltec_ros2/install/turn_on_wheeltec_robot/lib/turn_on_wheeltec_robot/cmd_vel_to_ackermann_drive.py --ros-args -r __node:=cmd_vel_to_ackermann_drive'].
  13. 1629123854.3081503 [ERROR] [wheeltec_robot_node-1]: process has died [pid 2161, exit code -6, cmd '/home/ubuntu/wheeltec_ros2/install/turn_on_wheeltec_robot/lib/turn_on_wheeltec_robot/wheeltec_robot_node --ros-args --params-file /tmp/launch_params_q44w_gn6 -r /cmd_vel:=cmd_vel'].
  14. 1629123858.6721938 [ERROR] [static_transform_publisher-4]: process[static_transform_publisher-4] failed to terminate '5' seconds after receiving 'SIGINT', escalating to 'SIGTERM'
  15. 1629123858.6768434 [ERROR] [static_transform_publisher-3]: process[static_transform_publisher-3] failed to terminate '5' seconds after receiving 'SIGINT', escalating to 'SIGTERM'
  16. 1629123858.6789229 [INFO] [static_transform_publisher-4]: sending signal 'SIGTERM' to process[static_transform_publisher-4]
  17. 1629123858.6892827 [INFO] [static_transform_publisher-3]: sending signal 'SIGTERM' to process[static_transform_publisher-3]
  18. 1629123858.6944149 [ERROR] [static_transform_publisher-4]: process has died [pid 2164, exit code -15, cmd '/opt/ros/eloquent/lib/tf2_ros/static_transform_publisher 0 0 0 0 0 0 base_footprint gyro_link --ros-args -r __node:=base_to_gyro'].
  19. 1629123858.6974823 [ERROR] [static_transform_publisher-3]: process has died [pid 2163, exit code -15, cmd '/opt/ros/eloquent/lib/tf2_ros/static_transform_publisher 0 0 0 0 0 0 base_footprint base_link --ros-args -r __node:=base_to_link'].
复制代码
151
355
695
695
发表于 2021-8-18 13:27:08 | 显示全部楼层
joint_state_publisher 这个包没装
GMT+8, 2025-4-20 15:27 , Processed in 0.067633 second(s), 24 queries .
