查看: 9547|回复: 1
N100 启动报如下2个错,请问如何解决?谢谢
10
57
57
发表于 2023-7-27 07:08:36 | 显示全部楼层 |阅读模式
king@ubuntu:~$ roslaunch fdilink_ahrs ahrs_driver.launch
... logging to /home/king/.ros/log/b291930e-2c08-11ee-a637-48b02d788332/roslaunch-ubuntu-4716.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://192.168.2.174:37875/
SUMMARY
PARAMETERS
* /ahrs_driver/baud: 115200
* /ahrs_driver/debug: False
* /ahrs_driver/device_type: 0
* /ahrs_driver/imu_frame: gyro_link
* /ahrs_driver/imu_topic: /imu
* /ahrs_driver/mag_pose_2d_topic: /mag_pose_2d
* /ahrs_driver/port: /dev/fdilink_ahrs
* /rosdistro: noetic
* /rosversion: 1.16.0
NODES
    ahrs_driver (fdilink_ahrs/ahrs_driver)
auto-starting new master
process[master]: started with pid [4724]
ROS_MASTER_URI=http://192.168.2.174:11311
setting /run_id to b291930e-2c08-11ee-a637-48b02d788332
process[rosout-1]: started with pid [4734]
started core service [/rosout]
process[ahrs_driver-2]: started with pid [4737]
[ INFO] [1690412637.420116143]: Serial Port initialized
[ INFO] [1690412637.421084552]: ahrsBringup::processLoop: start
[ WARN] [1690412637.476830990]: check crc16 faild(ahrs).
[ WARN] [1690412637.499135356]: check crc16 faild(ahrs).
[ WARN] [1690412637.521827604]: check crc16 faild(ahrs).
[ WARN] [1690412637.546666816]: check crc16 faild(imu).
[ WARN] [1690412637.565940567]: check crc16 faild(imu).
[ WARN] [1690412637.588929285]: check crc16 faild(ahrs).
[ WARN] [1690412637.633223438]: check crc16 faild(imu).
[ WARN] [1690412637.655956416]: check crc16 faild(imu).
[ WARN] [1690412637.677908960]: check crc16 faild(imu).
[ WARN] [1690412637.723112042]: check crc16 faild(imu).
[ WARN] [1690412637.744894593]: check crc16 faild(imu).
[ WARN] [1690412637.766857119]: check crc16 faild(imu).
[ WARN] [1690412637.792793393]: check crc16 faild(ahrs).
[ WARN] [1690412637.812036108]: check crc16 faild(ahrs).
[ WARN] [1690412637.834908779]: check crc16 faild(imu).
[ WARN] [1690412637.902051062]: check crc16 faild(imu).
[ WARN] [1690412637.923777525]: check crc16 faild(imu).
[ WARN] [1690412637.946036682]: check crc16 faild(ahrs).
[ WARN] [1690412637.971623661]: check crc16 faild(imu).
[ WARN] [1690412637.990946397]: check crc16 faild(imu).
[ WARN] [1690412638.012897666]: check crc16 faild(imu).
[ WARN] [1690412638.035833133]: check crc16 faild(imu).
[ WARN] [1690412638.060572670]: check crc16 faild(ahrs).
[ WARN] [1690412638.079841030]: check crc16 faild(ahrs).
[ WARN] [1690412638.102821835]: check crc16 faild(ahrs).
[ WARN] [1690412638.146783914]: check crc16 faild(ahrs).
[ WARN] [1690412638.169825095]: check crc16 faild(ahrs).
[ WARN] [1690412638.191790105]: check crc16 faild(ahrs).
[ WARN] [1690412638.217543516]: check crc16 faild(imu).
[ WARN] [1690412638.236808869]: check crc16 faild(imu).
[ WARN] [1690412638.258840846]: check crc16 faild(ahrs).
[ WARN] [1690412638.303810209]: check crc16 faild(imu).
[ WARN] [1690412638.325861191]: check crc16 faild(imu).
[ WARN] [1690412638.348826702]: check crc16 faild(imu).
ahrs_driver.launch文件配置如下:
<launch>
  <node pkg="fdilink_ahrs" name="ahrs_driver" type="ahrs_driver" output="screen" >
    <!-- 是否输出debug信息 -->
    <param name="debug"  value="false"/>
    <!-- 串口设备,可通过rules.d配置固定 -->
    <param name="port"  value="/dev/fdilink_ahrs"/>
    <!-- <param name="port"  value="/dev/fdilink_ahrs"/> -->
    <!-- 波特率 -->
    <!--<param name="baud"  value="921600"/>-->
        <param name="baud"  value="115200"/>
    <!-- 发布的imu话题名 -->
    <!--<param name="imu_topic"  value="/mobile_base/sensors/imu_data"/>-->
        <param name="imu_topic"  value="/imu"/>
    <!-- 发布的imu话题中的frame_id -->
    <param name="imu_frame"  value="gyro_link"/>
    <!-- 地磁北的yaw角 -->
    <param name="mag_pose_2d_topic"  value="/mag_pose_2d"/>
    <!-- 发布的数据基于不同设备有不同的坐标系   -->
    <param name="device_type"  value="0"/> <!-- 0: origin_data, 1: for single imu or ucar in ROS, 2:for Xiao in ROS -->  //这里改成0和1都无效
  </node>
  <!--<include file='$(find fdilink_ahrs)/launch/tf.launch' />-->
</launch>
最后,通过rostopic echo /imu 查看话题事件,无数据
260
778
778
发表于 2023-8-14 18:17:07 | 显示全部楼层
1.check crc16 faild报错
这里数据校验不通过,原因可能是数据量太大,波特率跟不上了。提高波特率或者减少数据输出类型、频率试下
2.rostopic echo /imu 无数据
如果ROS没有数据,先去Windows上用上位机检查一下是否关闭了数据的输出,或者尝试恢复出厂设置
GMT+8, 2025-4-18 22:05 , Processed in 0.089127 second(s), 21 queries .
